view q6600 VID in Vista 64bit?
11 Jul 2007
Southampton
i've tryed CoreTemp, but it doesn't work in 64bit Vista :mad:
what other application can i view VID of my CPU??
i've found in Everest-> Motherboard-> CPU page, there's a core voltage reading. is this the voltage im looking for?
it says 1.325v, if this is the VID, i must be really unlucky :(
Yip the Core Voltage in Everest is the same as my VID.
There's a version of CoreTemp that runs on x64 Vista here.
many thanks, ran the BAT first, then load up coretemp. it works now :D
1.325VID :( no wonder i need high voltages to get 3.6Ghz........ i tryed 1.50v on my Abit iP35 Pro and it still crashes Prime! (400 FSB 100% stable, running 400x8 all the time)
@fornowagain, great FSB speed, what setting did you set your iP35 Pro to to achieve that? i doubt my RAM will go that high, but i still want to have a rough idea.
