View syntax/code within a .bin file
28 Feb 2006
Beds
Is there a way to view the contents of a bin file? The file i have is an update file and i want to see the code its going to execute.
Thanks.
You can't see the contents of a pre-compiled binary (bin file) unless you reverse engineer it. If it's a linux application then chances are it will be open source and you can find the source code somewhere, otherwise you're in for a long haul.
Open it in a hex editor and you can see the 'code' it's going to run, whether or not you'll be able to make sense of it is another matter though!
Ive tried to look at the code using WinHex but couldn't see much. These are files used to jailbreak a device so i cant find any source code.
How do you reverse engineer a bin file?
It will contain compiled code. And you can look at that but you will need to understand assembly. I'm guessing it contains a firmware image or similar?
You can disassemble the file using something like objdump -M intel -D /path/to/file.bin you might need to add -b binary into the mix to. It will be a lot of code so pipe it out to a file rather than the default output stream.
