Ok quick question.
They say in my case 40 inch HDTV that for 1080p you should sit within about 4 feet to get benefits. They say for 720 sit within 8 feet.
Does this mean If I sit at 8 feet I will get as good a picture with 720p as 1080p?
In other words I cant see the benefits off 1080p at 8-10 feet so may as well use 720p or less resoltion?
Or Will 1080p still look a better quality picture than 720p at 8-10 feet? Its just not as good for details as 3 feet
really you should just experiment and try it yourself. If the source material is high res to begin with, lowering the res will always degrade it. I swear the people that say there is no difference are either liars, charlatans, blind or stupid (trying to compare using source material that was recorded at low res to begin with.)
