Viewsonic 20.1" VX2025wm Widescreen
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
The VA2012W is part of Viewsonic's more budget design VA range. It uses an 8ms TN Film panel which is different from the panel used in the VX2025. The VX2025 is a different design and uses the same 8ms P-MVA panel from AU Optronics as used in the Belinea 102035W, and soon to be many other new 20"WS models.
ah sorry mate, i thought you might have mistyped the model number. Not sure what has happened to the VA2022, they could well have changed the model number though, it's not listed on the website :(
