Found a LG 32GN650-B Ultragear Gaming Monitor 32” QHD (2560 x 1440) Display, 165Hz Refresh Rate, 1ms MBR, HDR 10, sRGB 95% Color Gamut, AMD FreeSync – Black thats sounds better.Personally I wouldn't touch a 32" 1080p monitor you'd pretty much be able to see all of the individual pixels which wouldn't make for a good overall experience. I went from a 27" 1440p to a 32" 1440p and although the additional size is a bonus the sharpness in games is definitely not as good, I can't imagine how bad it would be in 1080p.
Definitely a better option.Found a LG 32GN650-B Ultragear Gaming Monitor 32” QHD (2560 x 1440) Display, 165Hz Refresh Rate, 1ms MBR, HDR 10, sRGB 95% Color Gamut, AMD FreeSync – Black thats sounds better.
That's another 1080p monitor like the Viewsonic. You would be better off with the LG you found which is 1440p. If money is an issue you could be better off looking at a 27" 1440p monitor as there are a lot more options and you would be much happier with the improvement over a 32" 1080p monitor.Found a LG 32ML600M-B 32” Inch Full HD IPS LED Monitor with HDR 10 - Black for a lot cheaper & it was on a the M was on Best 32-Inch Monitor in 2021 - [Top 5 Picks For Any Budget]so the B is prob. better.
