Viewsonic VP920
the VP920 is using a 4ms TN Film panel, which should offer some decent responsiveness for gaming. However, being TN Film the viewing angles are pretty restrictive especially vertically, and movie playback isn't the greatest. Still, if you're looking for a gaming screen it's a good bet along with some of the more well known models like the VX924, VX922 and Samsung 930BF for example
crazyfewl said:
thanx for the reply,
so you reckon its on par with vx924 and 930bf etc using similar technology
similar, yes. Not as well known or as well established, but should offer some decent gaming performance.
Hi there
This is a project monitor from Viewsonic hence why OcUK is probably the only UK etailor with it. If it does well it will become a mainstream product and Viewsonic are pitching it directly against the Samsung 930BF. Its certainly a good monitor and between it and the 930BF they are very equal, guess just go for the one you preferre the look off. :)
