Viewsonic VP930 Question
16 Jun 2006
Viewsonic VP930 50hz Question
Hi,
I was thinking about upgrading my ageing 21" CRT with a Viewsonic VP930.
One thing I currently do with the CRT is change the refresh rate to 50hz with powerstrip so I can play all those old PAL 50hz console and computer emulators without any screen judder.
Will I be able to do this with the VP930? The tech spec says it has a vertical refresh range of 50-85hz...
No, you can only set the refresh rate between 60Hz and 75Hz. However, TFT's do not refresh in the same way as a CRT and so this shouldn't be an issue anyway. Since there's is no cathode ray gun refreshing the image across the screen as with a CRT, flicker is not an issue on TFT's.
That is a shame. This will definately cause a problem with scrolling 50.12 Hz games as at 60hz it will be displaying some frames twice which results in a juddering effect. My laptop LCD is fixed at 60hz and the results are not pretty.
