Hi guys, first time posting here so bear with me
Recently I have been having troubles with this monitor, or my rig, cant make up my mind.... First I should list specs :
Tagen 900w, Abit A8n32 SLI with FX60 Dual, Corsair 2GB DDR2 XMS2-8500 TwinX (2x1GB), GeForce 7950 GX2, Ageia PhysX, X-Fi Fatality, XP Pro Sp2
Problem is that the monitor keeps blacking out, as in, it might run for a while say anywhere from 20 seconds to 20 minutes fine, then you would loose the picture. Maybe loose the picture isnt the right word, it would appear the back light has turned its self off, since the computer runs fine, hasnt crashed, and you can still vaugly see whats on the screen. It appears to work fine on another computer but I havent left it running all that long. Could the cable be knackered? I have updated both the monitor drivers and the gfx drivers, still to no avail... Any ideas?
Fraser
Fraser
