Viewsonic VX912 Question
Permabanned
17 Aug 2004
Pencoed
Whats the difference between a VX912 and a VX912B?
I *think* i have a VX912, says 8ms on the box, yet i've seen people quoting them as 12ms too?
I need some clarification
Thanks
Tom
the B version iirc was supposed to be the black edition. The VX912 always used to be a 12ms panel, and then Viewsonic updated the spec without changing the model number as they have done with many other models in the past too. They changed it to 8ms, so if your box said 8ms then you should have the 8ms edition.
