Hi all,
not sure how many of you use vim (maybe I should have put this in the programming section!) but this extension to firefox allows you to use vim style in firefox
just started using it now, and it works pretty well. I like the way you can select links etc.
If you like vim you should give this a go, but check the help pages - they are very useful!
help).
Does anyone know of any other cool apps that turn normal applications into "vim style"? I have seen the viemu for office, however it isn't free, but I will try it out to see if I like it.
I'd love to have vim completely integrated into windows
but I know that isn't going to happen
Thanks,
Daven
help).Does anyone know of any other cool apps that turn normal applications into "vim style"? I have seen the viemu for office, however it isn't free, but I will try it out to see if I like it.
.Thanks,
Daven
