- 11 May 2007
- Surrey
I have a Creek CAS4040 hooked up to Kef Q35s with the following:
1) Disc input: Rega Planar 3 with RB250 tonearm
2) Tuner input: My PC via lineout from Steelseries Wireless Receiver
3) Aux/CD input: A Pioneer PDM550 6 disc player
I get really bad hum noise on from my TT and from my PC, but none from my CD player.
What's weird is that the Disc/TT noise is uniform and gets louder as you crank the volume. I think the tonearm should have an earth but it currently doesn't have one. So maybe that's the solution for that.
As for the PC, the noise is apparent with the volume down at 7 o clock position. When turned up to about 10 o clock on the dial, the noise goes away, and then comes back getting louder all the way to max volume at 5 o clock position. I can also hear the CD output very faintly when Tuner/PC is selected with a CD playing. I get the same noise any symptoms from the PC even with the minijack going straight to the soundcard.
Is it time to scrap the amp for something a bit more modern? Any help would be gratefully recieved.
