Stuck some 2000MHz ram on a Asus P8P67 Pro, but can't get it to boot correctly above 1333MHz
It should run at 1866 ok (as SB doesn't support 2000MHz directly, so should choose the next setting down), but from a cold boot it hangs with the memory LED on the board showing a problem. Reboot at that point when there is already power to the board, and the system works fine. However, power down entirely and reboot, and it hangs again. If I try to autodetect the ram, it only detects it as 1066MHz.
Anyone here using any 1600MHz+ ram on this board with no issues? If so, what make/model?
