Virgin ADSL
24 Nov 2002
38.744281°N 104.846806°W
My adsl is being iffy ever since we moved. I'm using the same settings, equipment, ISP and even exchange.. but my ping is usually shockingly high (>250), although sometimes as low as 8ms. The only difference is at my old house it was 8mb+ now it's ~5mb. I'm assuming it is the line or something, but BT say it isn't.
Below are my ADSL info from my router:
Code:
Status:
 Configured
 Current
Line Status
 SHOWTIME
Link Type
 Interleaved Path
Data Rate:
Stream Type
 Actual Data Rate
Upstream
 448 (Kbps.)
Downstream
 5120 (Kbps.)
Operation Data / Defect Indication:
Operation Data
 Upstream
 Downstream
Noise Margin
 26 dB
 7 dB
Attenuation
 52 dB
 41 dB
Indicator Name
 Near End Indicator
 Far End Indicator
Fast Path FEC Correction
 0
 0
Interleaved Path FEC Correction
 884
 1059662
Fast Path CRC Error
 0
 0
Interleaved Path CRC Error
 9
 333
Loss of Signal Defect
 0
Fast Path HEC Error STR
 0
 0
Interleaved Path HEC Error
 0
 0
Statistics:
Received Cells
 2539002
Transmitted Cells
 589112
