Virgin BB and Powerline/homeplug problem
24 Nov 2005
Skelton in Cleveland
Hi,
I am looking for a bit of advice for a friend who is having some beef with the above equipment.
Basically up until 3 or 4 weeks ago my friend had BT Broadband installed, his computer upstairs was connected to this via a Max Value 85Mbps homeplug.
Since then he has had Virgin BB installed, now the internet is fine on the PC downstairs and he is getting decent enough speeds upstairs via the homeplug (about 5Mb) but he is having terrible problems gaming.
Whilst gaming he is suffering terribly from lag and disconnections, my initial thoughts were that the homeplug was the problem, but i would like other opinions on this before we try other things and start throwing money at it.
Some Technical details for the home plug system.
Product Features
High-Speed Powerline adapter with Ethernet interface for fast data transfer over existing household electrical circuit
Fully compatible with HomePlug 1.0 & Homeplug Turbo
56 Bit AES Link Encryption with Key Management for secure communication
High-Speed transfer rates of 85 Mbps makes it possible to transfer any type of data
Use existing electrical wiring at any power sockets with up to 200mtrs operation range
Simple plug and play installation
Fully compliant with IEEE 802.3/802.3u 10/100Mbps RJ45
Supports 10/100 fast Ethernet Connection
Supports Auto MDI / MDIX
Allows users to connect PCs, notebooks and other Ethernet devices via any power socket
Low power consumption
Technical Details
Plug & Play
Peer to Peer Networking
56-bits DES link encryption with key management
ODFM modulation
Supports QAM, 256 / 64 / 16 DBPSK, DQPSK, ROBO
Integrated Quality of Service (QoS)
Compatible with Windows ME, 2000, XP & Vista, Mac OS & Linux Operating systems
Any help will be much appreciated.
