- 23 Dec 2013
Ok guys new member here, and new to fibre connectivity, so go easy on me please.
Long story shortened. We have an ongoing Leased Line install saga. 2 sites about 7 miles apart, we currently have a 10mb Legacy NTL/Virgin Leased line and wanted to upgrade to 1gb. Virgin couldnt upgrade the existing kit so offered a completely new install, and subbed the whole job out to BT. then the problems began, because Virgin and BT dont talk to each other.
After 6 months, Ive finally got a line installed, BT have signed it off, but it wont connect to our network.
At one end we have a ADVA FSP150CM router and a BT supplied fibre cable/loop which has a mini SFP connector into the ADVA device and an unknown end which looks like an SC Duplex. At the other site we have a ADVA FSP150CP with the same cable issue as above, an unknown interface.
We have HP procurve switches at both sites which have fibre SFP connectors. Our IT company have tried a fibre cable with Mini SFP connectors at both ends looped from the ADVA device into the procurve ( same at both sites) but the line just wont work.
BT have signed the leased line off as being active and handed the job back to Virgin, but we have had no technical help with getting the kit onto our network and Virgin and BT are not forthcoming after being pushed.
Im pulling my hair out and desperate to get the line live as its delaying an urgent project.
Can anyone advise? Is there some specific kit needed?
thanks.
thanks.
