- 7 Aug 2003
- Bristol
Recently (last week) my internet seems to stop working randomly..
All is fine after rebooting the modem, but it did not used to do this.
Before i speek to the monkeys on the phone i thought i would ask here..
Im in bristol if this helps.
Thanks in advance.
Rob
See below for info from modem.
DownStreem
UpStream
Error Log
Thanks in advance.
Rob
DownStreem
Code:
Frequency 307000000 Hz
Signal To Noise Ratio 41.0 dB
Power Level 9.7 dBmV
UpStream
Code:
Channel ID 1
Frequency 25800000 Hz
Power 30.5 dBmV
Error Log
Code:
2009-11-19 21:29:54 3-Critical T005.0 SYNC Timing Synchronization failure - Loss of Sync
2009-11-19 20:39:10 4-Error E108.0 SW upgrade Failed after download - SW File corruption
2009-11-19 20:39:10 6-Notice E102.0 SW Download INIT - Via Config file M8b93b82fa0d36f39.cm
1970-01-01 00:00:10 3-Critical D003.0 DHCP WARNING - Non-critical field invalid in response.
2009-11-19 20:38:38 4-Error E108.0 SW upgrade Failed after download - SW File corruption
2009-11-19 20:38:38 6-Notice E102.0 SW Download INIT - Via Config file M8b93b82fa0d36f39.cm
2009-11-19 20:38:35 3-Critical D003.0 DHCP WARNING - Non-critical field invalid in response.
2009-11-19 20:38:25 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-19 20:38:22 6-Notice M572.0 Ds Lock Failed - Reinitialize MAC...
2009-11-19 20:38:21 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-19 20:38:20 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-19 20:38:20 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-19 20:38:17 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-19 20:38:16 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-19 20:38:16 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-19 20:38:15 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-19 20:38:11 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-19 20:38:10 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-19 20:37:54 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-19 20:37:53 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-19 20:37:52 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-19 20:37:52 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-19 20:37:51 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-19 20:37:50 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-19 20:37:47 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-19 20:37:47 6-Notice M572.0 Ds Sync Failed - Reinitialize MAC...
2009-11-19 20:37:47 3-Critical T005.0 SYNC Timing Synchronization failure - Loss of Sync
2009-11-19 20:37:41 6-Notice M572.0 Ds Sync Failed - Reinitialize MAC...
2009-11-19 20:37:41 3-Critical T005.0 SYNC Timing Synchronization failure - Loss of Sync
2009-11-19 20:37:39 3-Critical R002.0 No Ranging Response received - T3 time-out (US 1)
2009-11-19 20:37:33 6-Notice M572.0 Ds Sync Failed - Reinitialize MAC...
2009-11-19 20:37:33 3-Critical T005.0 SYNC Timing Synchronization failure - Loss of Sync
2009-11-19 20:37:29 6-Notice M572.0 T4 No Station Maint Timeout - Reinitialize MAC...
2009-11-19 20:37:29 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
2009-11-19 20:37:28 3-Critical T005.0 SYNC Timing Synchronization failure - Loss of Sync
2009-11-19 20:08:26 3-Critical R005.0 Started Unicast Maintenance Ranging - No Response received - T3 time-out
2009-11-19 20:02:48 3-Critical T005.0 SYNC Timing Synchronization failure - Loss of Sync
2009-11-19 16:53:40 3-Critical R005.0 Started Unicast Maintenance Ranging - No Response received - T3 time-out
2009-11-19 16:17:48 4-Error E108.0 SW upgrade Failed after download - SW File corruption
2009-11-19 16:17:48 6-Notice E102.0 SW Download INIT - Via Config file M8b93b82fa0d36f39.cm
2009-11-19 16:17:32 6-Notice M571.1 Ethernet link up - ready to pass packets
2009-11-19 16:17:28 6-Notice M571.4 Ethernet link dormant - not currently active
1970-01-01 00:00:09 3-Critical D003.0 DHCP WARNING - Non-critical field invalid in response.
1970-01-01 00:00:03 6-Notice M571.1 Ethernet link up - ready to pass packets
1970-01-01 00:00:02 6-Notice M571.4 Ethernet link dormant - not currently active
2009-11-18 21:42:23 4-Error E108.0 SW upgrade Failed after download - SW File corruption
2009-11-18 21:42:23 6-Notice E102.0 SW Download INIT - Via Config file M8b93b82fa0d36f39.cm
2009-11-18 21:42:20 3-Critical D003.0 DHCP WARNING - Non-critical field invalid in response.
2009-11-18 21:42:12 3-Critical R002.0 No Ranging Response received - T3 time-out (US 1)
2009-11-18 21:42:01 3-Critical R002.0 No Ranging Response received - T3 time-out (US 3)
2009-11-18 21:41:46 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:41:45 6-Notice M572.0 Ds Lock Failed - Reinitialize MAC...
2009-11-18 21:41:44 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:41:44 6-Notice M572.0 Ds Lock Failed - Reinitialize MAC...
2009-11-18 21:41:43 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:41:42 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-18 21:41:41 6-Notice M572.0 Ds Lock Failed - Reinitialize MAC...
2009-11-18 21:41:40 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:41:40 6-Notice M572.0 Ds Lock Failed - Reinitialize MAC...
2009-11-18 21:41:39 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:41:38 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-18 21:41:37 6-Notice M572.0 Ds Lock Failed - Reinitialize MAC...
2009-11-18 21:41:36 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:41:35 6-Notice M572.0 Ds Lock Failed - Reinitialize MAC...
2009-11-18 21:41:34 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:41:32 6-Notice M572.0 Ds Lock Failed - Reinitialize MAC...
2009-11-18 21:41:32 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:41:31 6-Notice M572.0 Ds Lock Failed - Reinitialize MAC...
2009-11-18 21:41:30 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:41:30 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-18 21:41:29 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:41:28 6-Notice M572.0 Ds Lock Failed - Reinitialize MAC...
2009-11-18 21:41:27 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:41:26 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-18 21:41:18 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:41:17 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-18 21:41:14 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:41:13 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-18 21:41:06 3-Critical R001.0 No Maintenance Broadcasts for Ranging opportunities received - T2 time-out
2009-11-18 21:39:49 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-18 21:39:45 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:39:44 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-18 21:39:41 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:39:41 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-18 21:39:40 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:39:40 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-18 21:39:35 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:39:34 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-18 21:39:24 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:39:24 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-18 21:39:17 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:39:16 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-18 21:39:15 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:39:15 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
2009-11-18 21:39:12 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
2009-11-18 21:39:11 3-Critical R001.0 No Maintenance Broadcasts for Ranging opportunities received - T2 time-out
2009-11-18 21:38:19 6-Notice M572.0 Ds Sync Failed - Reinitialize MAC...
2009-11-18 21:38:19 3-Critical T005.0 SYNC Timing Synchronization failure - Loss of Sync
2009-11-18 21:38:15 6-Notice M572.0 T4 No Station Maint Timeout - Reinitialize MAC...
2009-11-18 21:38:15 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
