- 20 Apr 2008
- West Midlands
i'm after some assistance/advice regarding my VM connections.
From the included pic (my drawing skills are weak
)we have two VM access points. The one in the front room is the one which is currently connected. But signal upstairs in the house from this location is extremely weak especially in my sons room which sits above the back half of our kitchen. He receives under 5mb over wifi so gaming and streaming isn't the best. We've home plugs installed but find we're having to keep rebooting them just to keep the connection together. When it works he receives upwards of 20mb.
Our house is a 1934 build so old thick walls to limit signal etc.
What i'm interested in knowing is can i utilise the second VM connection to boost my signal through the house.
Is this possible?
If so what is the best form of connections to use etc.
)we have two VM access points. The one in the front room is the one which is currently connected. But signal upstairs in the house from this location is extremely weak especially in my sons room which sits above the back half of our kitchen. He receives under 5mb over wifi so gaming and streaming isn't the best. We've home plugs installed but find we're having to keep rebooting them just to keep the connection together. When it works he receives upwards of 20mb.Our house is a 1934 build so old thick walls to limit signal etc.
Is this possible?
