50Mbps Virgin Media. Not the greatest results, but there's always traffic going through it and I'm on wireless.
Ping is as you'd expect for a wireless connection, good but not stable.
Pinging jolt.co.uk [84.234.17.86] with 32 bytes of data:
Reply from 84.234.17.86: bytes=32 time=23ms TTL=117
Reply from 84.234.17.86: bytes=32 time=22ms TTL=117
Reply from 84.234.17.86: bytes=32 time=39ms TTL=117
Reply from 84.234.17.86: bytes=32 time=47ms TTL=117
Reply from 84.234.17.86: bytes=32 time=19ms TTL=117
Reply from 84.234.17.86: bytes=32 time=42ms TTL=117
Reply from 84.234.17.86: bytes=32 time=25ms TTL=117
Reply from 84.234.17.86: bytes=32 time=20ms TTL=117
Reply from 84.234.17.86: bytes=32 time=62ms TTL=117
Reply from 84.234.17.86: bytes=32 time=85ms TTL=117
Reply from 84.234.17.86: bytes=32 time=108ms TTL=117
Reply from 84.234.17.86: bytes=32 time=107ms TTL=117
Reply from 84.234.17.86: bytes=32 time=32ms TTL=117
Reply from 84.234.17.86: bytes=32 time=24ms TTL=117
Reply from 84.234.17.86: bytes=32 time=40ms TTL=117
Reply from 84.234.17.86: bytes=32 time=27ms TTL=117
Edit
Wifi is crap for stable connection (255.1 is my router).
Pinging 192.168.255.1 with 32 bytes of data:
Reply from 192.168.255.1: bytes=32 time<1ms TTL=64
Reply from 192.168.255.1: bytes=32 time=4ms TTL=64
Reply from 192.168.255.1: bytes=32 time=1ms TTL=64
Reply from 192.168.255.1: bytes=32 time=81ms TTL=64
Reply from 192.168.255.1: bytes=32 time=21ms TTL=64
Reply from 192.168.255.1: bytes=32 time=45ms TTL=64
Reply from 192.168.255.1: bytes=32 time=69ms TTL=64
And a wired counter part of 50 "pings".
Ping statistics for 192.168.255.1:
Packets: Sent = 50, Received = 50, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
