Evening,
After getting off the phone with Virgin it looks like my 1mb a sec speed is 'still a service' and they won't replace my router. I can for the price of £25 have an engineer come out to TS as they won't replace the hub outright as the problem will 'fix itself' I'm tied in till Feb or i'd have cancelled there and then, but after my own checks I found a wired connection was 100mb+ so thought about a WIFI 6 router replacement.
I believe its just a case of sticking the hub in to modem mode, ethernet to new router and away I go. Problem is I just don't know which one, so thought you'd may be able to help.
So far I've been looking at the £40-70 mark as although I refuse to pay them £25 I am willing to pay more to cut them out of the equation as much as I can, but not to go daft.
Candidates are:
Tenda RX3 AX1800 or RX9 Pro AX3000
HUAWEI AX3 AX3000
Asus RT-AX55
TP-Link AX1500
Cheers,
Candidates are:
HUAWEI AX3 AX3000
Asus RT-AX55
TP-Link AX1500
Cheers,
