Virgin Media 1Gig Broadband Asus Wifi6 very slow
1 Dec 2017
I’ve currently got Virgin Media 1 Gig Broadband which is painfully slow. I’ve bought an ASUS Wifi6 Mesh network but on Wireless 2.4 or 5GHz it’s about 60mbps download and upload is 25mbps. I’ve done the latest firmware updates. Anything else I could try?
What are your speeds like connected directly to the VM hub's AP?
The measured speed in the OP is the first mesh AP which is using a wired connection in to the VM hub?
That’s correct. I’m not sure what they are like as the VM Super Hub 4 is in Modem Mode.
You've run the speed test on multiple devices and all give the similar results?
Does the mesh have a built in speed test tool?
What's the model of your Asus mesh?
It has a built in speed test tool, I’m just trying that now.
ASUS details are
ASUS ZenWiFi AX Whole-Home Tri-Band Mesh WiFi 6 System(XT8)​
So no issue with the connection back to the hub/modem, just the WiFi on the Asus device.
Have you tried with multiple devices. Maybe a tweak it needed on the connecting devices profile or it doesn't support higher speeds.
I’ve tried with multiple devices. It’s currently set for Gaming. I will see what that does. It seems to throttle the upload speed. Which you think would be higher than 50mbps.
