Recently i moved back to my student digs and we have virgin media 20mg cable and have done for a year now. However 2nite the connection went..well abit mental. Our whole house (6 bedrooms) is etherneted up so at first i thought it must be that so i connected directly to the router (modem connects to the wireless router from there we run a cable to the closet under the stairs to a switch and then the connection is divided up for the house) via the switch using my desktop pc lan. The connection still continued to play up, dropping every so often at random times.
I decided to try different ethernet cables that connect from the back of my pc to the switch but no luck, i then tried my laptop using the ethernet at first but still the connection dropped and then i tried the wireless however that still dropped.
For some reason our past tennants left their old virgin cable modem behind ( i think) but for whatever reason we have 2 black virgin media cable modems, seeing as the original was playing up and im certain is not the router or the switch or the cabling in the house i decided to plug the old modem in a give it a swirl, it connected but brought me to a setup page, like you would get after your connection is activated for the first time and you setup your login details etc etc. Seeing as my house mate whos the owner of the net connection (his name is on the bill) i didnt proceed any further but i was still able to browse the web. I then pluged the original router in and the same page/welcome/log in/setup page appeared, i closed it and now im here.
But so far so good, the connection is stable with no timeouts, ive been able to connect to mIRC, browse and have eve online running. If for whatever reason the cable router is definetly the problem, does virgin allow the use of other cable modem routers to be used?
tl:dr
can i use a different cable modem router instead of using virgins black cable modem and router combo?
tl:dr
