Hi there lads i am having quite a lot of trouble with my internet connection it constantly times out and my modem needs the power taking out and then putting back in again a lot i use a netgear WGT624 v3 and i cannot find any other versions of firmware so i believe its upto date i run 2 computers and an xbox 360 through ethernet cables and have two laptops on wireless.
I have emailed virgin media and they seem to think its me. I was unconvinced at first but i was thinking it was possibly my router but cant be 100% sure(there customer service was no help as usual). I run the wireless settings on g and b as this was the default settings and i dont no a great amount about them. Or if i should just switch it to a g setting.
Its a virgin media business line at 10mb which sucks as the 20mb had some port restriction or something which conflicted with to many programs so i had to downgrade which i believe this costs me the same amount... and they say im binded to a contract that was signed which ofc i was never signed or even heard about... but ye thats life
I have checked all the logs that i can find and i see nothing wrong, other than that i cant say a lot more other than it randomly starts to slow down gitters reconnects every now and again then will drop sometimes not wanting to reconnect for 10 mins other times reconnecting instantly, others it will just timeout instantly and reconnect i normally just restart my modem ocasionally i have to restart both...
hope you lads can think of something if not i will try another router if u have any decent suggestions it needs to be quite fast and for 3 wired pcs and xbox and 2 wireless laptops
Many thanks for your time
Ben
Ben
if not can i ask what tests i could ask virgin media to run just to see if it is the line or anything else
