Hi everyone - I am looking for some advice from you very clever people. Please note: I only have basic networking knowledge.
As per the title, I have a virgin media superhub 3, which previously met my requirements perfectly. We have fibre 350 and generally get 200+ which is great. We have turned part of our garage (brick-built, standalone about 5 meters away from the house) into an office as my wife and I both work from home regularly now.
I was gifted an Asus Lyra Mini x3 mesh wifi set and have tried to set this up to get a couple of times. The first time I plugged the main (router) Lyra mini into the back of the hub and then managed to get the other two paired with it, but this created a second Wifi Network with a much lower speed (50-70mbps)
Second attempt I put the hub into modem mode, but this knocked out my internet from Virgin (or coincided with a virgin drop in service) and I reset everything and went back to just using the hub.
I just paid someone from a local computer shop to come and install the Lyra Mini mesh, and I am amazed at how poorly it performs. The guy just plugged the main (router) lyra mini into the WAN port at the back of the VM hub and has again created a second network - that signal is picked up by a node in the garage and when I connect to this second wifi network - I only have speeds of 30-50mbps. Which is much less than I expected. I have just unplugged the Lyra Mini and plugged in a TP-Link powerline and get 55mbps (wired) in the garage which is far simpler.
My questions are really :
1. Should the Asus Lyra Mini be performing better?
2. Does this sound like it was set up correctly by the guy i paid?
3. How can I get the best internet in my garage? happy to run ethernet to the garage, but would want a wireless connection for my laptop/wifes laptop ideally once inside?
4. Any tips or ajustments can i make for better signal in the garage?
thanks all!
thanks all!
