Virgin Media Hub 3 problems...
12 May 2010
West Bromwich
- The missis folks were recently talked into upgrading to a Hub3 by Virgin Media which worked fine for 3 months or so but recently shows signs of being borked.
- I need some gumpf I can phone their tech support with
- Basically, the problem started with the router stuck in a boot loop trying to do a firmware upgrade (completely by itself)
- I talked to her folks, and they said that VM 'did something down the line, and the white light came on the front, and they said it would be ok'
- Now, it seems to loose connection every 5 mins or so, then starts to work again, then loose connection.
- Weirdly, wifi works fine.
A lad on VM forums suggested I get CAT6 lan cable, because it could be that. Is that needed for 200Mbps ?
Thanks anyone who can think of a possible cause.
WIFI doesnt support 200mb, so you need to be connected via your Ethernet cable to achieve full speed irregardless. It does sound like your cable though tbh.
I also use "WIFI analyzer" free on the play store to check my wifi channel against my neighbours.If there both using the same one, them move it to a one which is clear.
