Hi,
just moved into a new property and am gonna need to have it hooked up to the net.
its in a cable area so think i'm going with virgin however i'm concerned about the £25 installation charge. the reason for this is the fact that there is a cable into the house and at the end of it is modem *the blue one - think its the ntl one*.
know do you think i'll be exempt from the charge bearing in mind it will be 4mb max on the line and everything is already there?
thanks in advance, oh and if anybody knows of any better deals out there give us a shout the postcode of the property is ln1 3jz if you need to check availability but it seems to be in an www friendly area.
Josh
Josh
