Does anyone know if VM block/sometimes block certain ports? im having trouble opening ports 80, 20, 21, 443 & 563.
I originally thought it was a problem with my router, I saw on some forums that the Netgear model I was using had a known problem with port forwarding. So I swapped it for my mothers and im getting the same problem, it was working fine up till a few weeks ago and ever since then its been on/off.
Port 3389 works fine for RDP and ports 5800/5900 are working fine for VNC.
My friends on VM and his port 80/20/21 are working fine, but his 563 is also blocked.
