Virgin Media Router Antenna?
26 Aug 2005
London
A friend of mine has a netgear wireless router and unfortunately the antenna snapped. Are the antennas all standard as I wanted to buy one seperately?
There's a couple of different sizes (diameters) then theres male or female and finally do you want the standard one or a slightly "better" uprated one which should give more speed/coverage
Netgears use RP-SMA if I recall, well I hope so as I've just placed an order for a Linksys RP-SMA 7db gain antenna.
