Virgin Media Super Hub Replacement
24 Dec 2011
I am getting VM installed tomorrow and do not want to be using the Superhub so im going to use it as a modem only and attach a good router
Im after one with good range (Old brick house), good features and doesnt break the bank
Preferably one i can pick up asap also
Please point me in right direction
EDIT: Will this work
NETGEAR WNR2200-100UKS N300 Wireless-N Router Google it i cant post competitors ofc
I want wireless in my bed room and some wired connections to my iMac & Xbox.
The Super hub is downstairs and wireless performance is poor in my room.
oh right ..so if you wanted to use your own router and have the superhub as a modem only would the VM engineer set this all up for you or do they prefer to use the VM Superhub supplied ??
would the engineer set this all up for you or do they prefer to use the VM Superhub ?
No idea. My guess is that they would set it up with the superhub and you would have to change it. I have both of them as wireless routers.
