Virgin Media Superhub problems
3 Dec 2005
Since we upgraded to 30mb about 6 months ago, we have had consistent reboots with the superhub. I'd guess we get roughly 10 per evening. As it acts as the router for my homeplugs than connect the pc to dnla tv, its really starting to get annoying.
Anyone else having these problems with the superhub and have any fixes?
My speed levels do drop during peak times and the are you on wireless or wired.
If your wired you might have a lot of other people in your street/area on the line or whatever it's called, and they will be taking badwith aswell (just a suggestion)
Its not really that the speed drops - just that the superhub completely resets itself. All the lights go off, then flash and it reboots. When its on the speeds are fine and actual connection to the pc or wireless laptops is solid.
