Virgin Media superhub
19 Apr 2010
Hey, i recently upgraded to 60mb internet with Virgin media and was given a superhub. Over wireless the speed maxes out around 20mb. Does anyone else have any similar experiences?
Inb4 Lan
Got mine today and ide say have a look at what channel its on. They seem to be pre-set at 11 and i put mine on Automatic and it solves many issues
They come pre set on Auto which is not great and neither is 300mbps.
Change it to another channel and change the speed to 145mbps
I read that they are now setting 145 as the default unless you're on the 100Mb service.
Nope default is always 300mbps but any technicians that come to your home to set up the superhub should always change it to 145mbps no matter what service.
300mbps is not stable when connecting to 802.11.n cards so if you want to use 300mbps unless you have your hub sent through the post you have to change it to that yourself
does the virgin engineer come inside the home to set up the router superhub etc ?
