virgin router
3 Jan 2010
Hailsham
can anyone spec me a good wirless router for my virgin 50mb service? i was gonna use my d link dir 615, i have started using a wirless home network to stream films around the hoouse. or should i just buy another second hand d link dir 615. dont want to spend to much, would like to pick up a second hand router if possible
The DIR615 is what Virgin used to supply to the 50meg customers before the lousy Superhub was issued.
I was not overly impressed with the 615 personally so i got a belkin N1 Vision which is working fine although some others have had issues with that too.
I'd try the 615 first and see how it goes.
