Virgin settings please
There are no specific settings required to work with VM cable other than you setting your wireless security / network IP's etc.
If its cable then you don't need any settings, just attach the modem in the correct port on the router and switch them on and as above, set up wireless security. There is no username or password like with ADSL.
