Virgin Super HUB connect existing router
7 Jan 2010
Up NORTH
Hi Forum,
Am I correct in saying I can connect my netgear wireless router to my new virgin hub so as to still broadcast from the my original router,
yes very easy to do.
basically you need to goto ip leasing and put your router on a static address. I used 192.168.0.10
dmz the router,
then disable the wireless.
restart both routers
Good idea to disable the firewall and ip flood options as well at this point.
log into the other router setup page and check the connection is working.
whole process takes no more than 10 minutes.
Disable wireless interface in the super hub.
make sure only one is the DHCP server, in fact a friend has disabled the router altogether in the super hub, just using the cable modem function and has his other router connected to the hub for wireless and ethernet routing.
i attempted this about a month ago when i got my SuperHub delivered. I managed to get it all working apart from NAT for my xbox. Connect directly to SuperHub = Status Open. go through a second hub and the NAT was restricted. Doesn't appear to be a work around the double NAT'ing.
Does that mean my sons xbox360 will not work?? On wireless
