Virgin SuperHub VESA Mount
18 Oct 2002
Glasgow
Hi Guys,
Wasn't sure if I should post this in the network section or this.
I recently had VM installed and the superhub is currently sitting by my TV in a bit of a cable mess.
I would like to clean this up but ideally would mount the superhub to the back of the TV using a VESA mount - trouble is I can't find anything universal or cage like that would work.
I don't mine using cable ties / velcro to mount it but would prefer it to be sitting on a solid base on the back of the tv as the cable may cause some strain.
Any ideas?
Thanks
R
you want something like the vesa mount from the Antec ISK110 mini itx
