Hi,
I'm using the SuperHub from Virgin which has a PC connected via Cat5 and two laptops via WiFi.
Currently the speed of the laptops is 144 Mbps. Both laptops are using NetGear USB WiFi dongles certified to 'N'. To try and get them to run at a higher speed do I just need to change the '802.11N Band' from 2.4 Ghz to 5?
Thanks & Regards
Thanks & Regards
