Hello all, I would like to talk about/ask for help with this issue.
I am a new customer and I am trying to decide if I need to get out of the contract while I am in my 14 day "cooling off window" before I get locked in. I had heard good things about it and they were offering some good prices as they have just reached my area.
However, I went for the M100 fibre option, it is advertised as 108Mbps down and 10 up. I know they are not obligated to give me 108 at all times, but the minimum "guaranteed" speed for this price range is 54 Mbps. When the engineer came and installed it all he had me run a speed test and my results were 108 on the nose and 8 for upload. Since then any time I open either vpn or p2p client my speed is instantly and consistently cut really badly, it drops to less than 3 download and the upload is so slow that speed tests cant even put a number on it, the tests just fail and give "connection time out" errors. I am on windows 10 pro x64 , have the hub 3 and I am running mullvad vpn, as for the p2p clients I have tried multiple and everything in this thread applies to all of them. I fully appreciate both the speed fluctuation that companies are allowed and that vpn will slow a connection down, but simply running a vpn shouldnt drop a "minimum" 54Mbps connection to speeds so low that a single device in a single person property cant load a 3 minute youtube video
I have tried a lot of things and the only conclusion I am left to draw is that virgin, despite their claims are indeed throttling
Set exceptions in antivirus/firewall
Disabled antivirus/firewall entirely
Used TCP/UDP and wireguard connection protocols
Used the various TCP/UDP port options
Tried many servers in many countries
Tried with and without IPV6 options
Tried enabling SOCKS5 proxy, as per mullvads own guide
Tested on wired and wireless connections
Tested on multiple devices
- Which are running multiple OS'
Turned off the "ip flood protection" in the router settings
Disabled the "websafe" and "virus scan" options that are turned on by default in "myvirginmedia" account settings
Tried changing the settings in p2p clients to limit number of connections aswell as upload/download speeds
And still I am in the same position, fast connection without those programs running, if I launch either one within mere seconds my connection is so slow I cant even load a youtube page yet when I close those types of programs within seconds my speed bounces back to normal.
I hope I am missing something obvious, i hope someone can call me an idiot and tell me I am missing something and there is a fix to this because right now I have just swapped from a bad ISP to one that is mostly regarded as fast and reliable but so far becomes dead in the water if I want a shred of privacy and want to run a vpn and I would rather avoid having to try and find a 3rd provider .
Thank you if you read all this
