diva# clear arp
diva# arp-req: generating request for scion at interface inside
arp-send: arp request built from 10.27.0.1 001e.f715.7a75 for scion at 12400150
arp-in: response at inside from scion 0030.1bae.20f2 for 10.27.0.1 001e.f715.7a75
arp-set: added arp inside scion 0030.1bae.20f2 and updating NPs at 12400150
arp-in: resp from scion for 10.27.0.1 on inside at 12400150
arp-send: sending all saved block to inside scion at 12400150
arp-req: generating request for 94.169.96.1 at interface outside
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12400740
arp-req: request for 94.169.96.1 still pending
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12401760
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12402760
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12406760
arp-in: request at inside from nexus bcae.c5b3.d3f8 for 10.27.0.1 001e.f715.7a75
arp-in: rqst for me from nexus for 10.27.0.1, on inside
arp-set: added arp inside nexus bcae.c5b3.d3f8 and updating NPs at 12409660
arp-in: generating reply from 10.27.0.1 001e.f715.7a75 to nexus bcae.c5b3.d3f8
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12411760
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12416760
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12421760
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12426760
arp-set: added arp inside nexus bcae.c5b3.d3f8 and updating NPs at 12430660
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12431760
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12436760
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12441760
show arp
inside nexus bcae.c5b3.d3f8 12
inside scion 0030.1bae.20f2 42
diva#
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12446760
conf t
diva(config)#
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12451760
arp-set: added arp inside nexus bcae.c5b3.d3f8 and updating NPs at 12452160
diva(config)# int eth0/0
diva(config-if)# shutdown
diva(config-if)#
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12456760
diva(config-if)# no shutdown
arp-send: arp request built from 94.169.96.79 001e.f715.7a75 for 94.169.96.1 at 12461760
arp-in: response at outside from 94.169.96.1 0030.b8d2.1450 for 94.169.96.79 001e.f715.7a75
arp-set: added arp outside 94.169.96.1 0030.b8d2.1450 and updating NPs at 12461800
arp-in: resp from 94.169.96.1 for 94.169.96.79 on outside at 12461800
show log
Syslog logging: enabled
Facility: 20
Timestamp logging: disabled
Standby logging: disabled
Debug-trace logging: disabled
Console logging: disabled
Monitor logging: disabled
Buffer logging: level debugging, 20005 messages logged
Trap logging: disabled
History logging: disabled
Device ID: disabled
Mail logging: disabled
ASDM logging: level informational, 15875 messages logged
on 3922 for outside:80.190.225.139/17385 to inside:nexus/61851 duration 0:02:01 bytes 17
%ASA-5-111008: User 'enable_15' executed the 'interface Ethernet 0/0' command.
%ASA-6-305012: Teardown dynamic UDP translation from inside:scion/44132 to outside:94.169.96.79/3777 duration 0:02:30
%ASA-4-411002: Line protocol on Interface Ethernet0/0, changed state to down
%ASA-4-411002: Line protocol on Interface outside, changed state to down
%ASA-4-411004: Interface Ethernet0/0, changed state to administratively down
%ASA-5-111008: User 'enable_15' executed the 'shutdown' command.
%ASA-6-110003: Routing failed to locate next hop for UDP from inside:94.169.96.79/45470 to outside:78.129.239.48/9987
%ASA-6-110002: Failed to locate egress interface for UDP from inside:nexus/51664 to 80.190.225.139/17385
%ASA-6-302016: Teardown UDP connection 3932 for outside:80.190.225.139/17385 to inside:nexus/58589 duration 0:02:01 bytes 17
%ASA-6-302016: Teardown UDP connection 3923 for outside:194.168.4.100/53 to inside:nexus/52180 duration 0:02:08 bytes 140
%ASA-6-302016: Teardown UDP connection 3924 for outside:194.168.8.100/53 to inside:nexus/52180 duration 0:02:07 bytes 105
<--- More --->
arp-in: request at inside from nexus bcae.c5b3.d3f8 for 10.27.0.1 0000.0000.0000
arp-set: added arp inside nexus bcae.c5b3.d3f8 and updating NPs at 12468760
arp-set: added arp inside nexus bcae.c5b3.d3f8 and updating NPs at 12468770
arp-set: added arp inside nexus bcae.c5b3.d3f8 and updating NPs at 12468780
arp-set: added arp inside nexus bcae.c5b3.d3f8 and updating NPs at 12468790
arp-set: added arp inside nexus bcae.c5b3.d3f8 and updating NPs at 12469160
%ASA-6-305012: Teardown dynamic UDP translation from inside:scion/45372 to outside:94.169.96.79/13575 duration 0:02:30
%ASA-7-710005: UDP request discarded from vorniz/41443 to inside:10.27.0.255/3052
%ASA-6-302016: Teardown UDP connection 3894 for outside:78.129.239.48/9987 to inside:nexus/54162 duration 0:03:54 bytes 64458
%ASA-7-609002: Teardown local-host outside:78.129.239.48 duration 0:03:54
%ASA-6-302016: Teardown UDP connection 3925 for outside:194.168.4.100/53 to inside:nexus/61591 duration 0:02:08 bytes 136
%ASA-6-302016: Teardown UDP connection 3928 for outside:194.168.8.100/53 to inside:nexus/61591 duration 0:02:07 bytes 102
%ASA-6-302016: Teardown UDP connection 3926 for outside:194.168.4.100/53 to inside:nexus/49220 duration 0:02:08 bytes 136
%ASA-6-302016: Teardown UDP connection 3929 for outside:194.168.8.100/53 to inside:nexus/49220 duration 0:02:07 bytes 102
%ASA-6-305012: Teardown dynamic UDP translation from inside:nexus/54739 to outside:94.169.96.79/10560 duration 0:02:30
%ASA-4-411001: Line protocol on Interface outside, changed state to up
%ASA-7-609001: Built local-host identity:94.169.96.79
%ASA-7-609001: Built local-host outside:62.30.64.114
%ASA-6-302015: Built outbound UDP connection 3972 for outside:62.30.64.114/67 (62.30.64.114/67) to identity:94.169.96.79/68 (94.169.96.79/68)
%ASA-4-411003: Interface Ethernet0/0, changed state to administratively up
%ASA-5-111008: User 'enable_15' executed the 'no shutdown' command.
%ASA-4-411001: Line protocol on Interface Ethernet0/0, changed state to up
%ASA-7-609001: Built local-host outside:78.129.239.48
%ASA-6-302015: Built outbound UDP connection 3973 for outside:78.129.239.48/9987 (78.129.239.48/9987) to inside:nexus/54162 (94.169.96.79/45470)
%ASA-6-302016: Teardown UDP connection 3930 for outside:194.168.4.100/53 to inside:nexus/58588 duration 0:02:08 bytes 148
%ASA-6-302016: Teardown UDP connection 3931 for outside:194.168.8.100/53 to inside:nexus/58588 duration 0:02:07 bytes 111
%ASA-6-305012: Teardown dynamic UDP translation from inside:scion/59395 to outside:94.169.96.79/34138 duration 0:02:30
%ASA-6-305011: Built dynamic UDP translation from inside:nexus/51665 to outside:94.169.96.79/53394
%ASA-6-302015: Built outbound UDP connection 3974 for outside:80.190.225.139/17385 (80.190.225.139/17385) to inside:nexus/51665 (94.169.96.79/53394)
%ASA-7-710005: UDP request discarded from 70.42.62.85/5062 to outside:94.169.96.79/14070
diva(config-if)# no debug arp
debug arp disabled.
