Virtu Control Panel stuck in "Trial Mode"
29 Dec 2003
Newcastle upon Tyne
Hi,
I've just set up my new build and upon installing the Virtu Control Panel I can't Add/Edit/Remove Application entries or switch the OSD mode, apparently this is because it is in trial mode. Does anyone know how I can get it registered? I'd have thought MSI would have provided a full copy of it with the motherboard!
Thanks,
Kona
Hi,
Thanks,
Kona
Same here, its a BIOS issue that they should be addressing.
You can try to contact them via their crappy support portal, but you get a lot of 'Engrish' back!
Yup I've literally just found this out myself via the MSI forums. I'm asking OcUK if I can return the board as it's missing an advertised feature - that on top of another problem I've had with it!
