Virtu MVP + Nvidia
9 Sep 2008
United Pingdom
Hello all,
Do you know if Virtu mvp 2.0 supports the 780ti?
I've tried trawling through the net for answers and can't find an answer.
Their latest software update was on 27th November, so I am asuming they have..
The reason I'd need to use this, is I have an apple thunderbolt display. And this is the only way I can get it to work. If Virtu mvp is incompatible with the 780ti I'll have to send the monitor off :(
Emailed the chaps, and they said latest version works with 780ti. Just incase anyone else comes across same issue.
There is no other way to connect the monitor to the monitor to a PC Greg :(
I'll be playing most games on my TV anyway. This is for the MMO stuff only.. I hate how annoyingly restricted apple products are :|
Ahhh I see what you mean. Sorry, I was having a blonde moment and thinking of Lucid Virtu, which gives massive fps but made the games seriously choppy.
