Virtu MVP showing as Evaluation Copy?
18 Oct 2002
Norwich
I've got a ASRock Z77 Extreme4 with 3570k which came with Virtu MVP. I was previously using version 2.1.111 of their website which ran fine as a full version but they've now got a version 2.1.112.21449 on their site which when installed shows as "Evaluation Copy".
Anyone got any ideas how to fix this? The Evaluation Copy won't let me hide the Virtu logo when playing games.
Thanks
Thanks for the suggestion, I had given that a go already (it makes you uninstall before installing new version anyway) with no luck, but I've had to format today which seems to have had the side effect of fixing this too. So no idea what causing this.
I ran virtu MVP with heaven on a moderate clock for my 680 just to see any difference and it crashed my comp. Was I doing something wrong anybody know?
Sorry to hijack the thread.
had the same issue with it, did you download it from the mvp website ? if you did thats not the version you need, you have to go to your motherboard manufacturers website and download there version. it fixed the Evaluation Copy problem
That would explain it. Thanks for the info and will have a fiddle later.
I think you need to install the motherboard manufacturers version first then you can update over the old motherboard manufacturers version with the MVP software on lucids site, I think the motherboard manufacturers version has the registeration files required to stop the evaluation problems if you update from Lucid.
I tried installing the version from my motherboard company then installing it from lucid's website. and It still shows as an evaluation copy..... :/
any help here?
