Virtual Box and mounting shared folders
Lee
Lee
21 Dec 2006
Northampton
Hi, I'm a bit of a Linux noob. I have installed Ubuntu 11.10 within a Virtual Box VM. I can manually enter the terminal command below to mount the Virtual Box shared host folder (Cosmos) to Home/host folder in the VM, and it works fine:
sudo mount -t vboxsf Cosmos ~/host
What I can't work out is how to automate this on bootup. I've googled and tried adding a line to the /etc/fstab file:
Cosmos /home/lee/host vboxsf defaults 0 0
which is as far as I tell exactly what is suggested, but it doesn't seem to mount the shared folder.
Can anyone help with this ?
Cheers,
Lee.
Have you tried adding this to your .xinit or to your startup?
use mount!
then:
i.e. make a bash script and just call it in either .xinit (possibly + delay) or your startup
If your not in wheel you may need to be a member of mount explicitly!
I think the OP means he's adding that line to the filesystem table of the virtual machine, not of the host. Which would mean it's a minor syntax error, but I can't remember the format required well enough.
One approach would be to add
@Reboot "mount -t vboxsf Cosmos /home/lee/host"
to root's crontab (by typing crontab -e to edit the crontab), but that's a workaround rather than a solution. It might need a sudo in there as well, it might not (I don't use sudo).
Guys, thanks for the pointers. Some of it is a bit beyond my current capability, but hell that's why I'm running a Linux VM, to learn...
