Hi Guys
I am looking to put a virtual machine host system together, and thought I would stop by and ask for some advice.
I want to build the physical machine, and run about 4 virtual machines off it. The machine will run a mixture of Server 2003/08, Vista and XP Pro OSs - and SQL Server 2005 will most likely be installed on one of those.
Now I know that the more RAM the better (I was looking at buying 8GB of DDR2) and dedicated hard drives for each virtual machine, but is there anything else you can recommend that would increase the performance of each virtual machine?
I already have a motherboard - its an Intel DG33TL.
Any advice would be greatly appreciated.
Thanks
Thanks
