The other option is to move it at the default size to a mechanical hard drive.
Microsoft recommend keeping the pagefile on your SSDas magicboy said, i would move it at default size to another hard drive.
Should the pagefile be placed on SSDs?
Yes. Most pagefile operations are small random reads or larger sequential writes, both of which are types of operations that SSDs handle well.
In looking at telemetry data from thousands of traces and focusing on pagefile reads and writes, we find that
Pagefile.sys reads outnumber pagefile.sys writes by about 40 to 1,
Pagefile.sys read sizes are typically quite small, with 67% less than or equal to 4 KB, and 88% less than 16 KB.
Pagefile.sys writes are relatively large, with 62% greater than or equal to 128 KB and 45% being exactly 1 MB in size.
In fact, given typical pagefile reference patterns and the favorable performance characteristics SSDs have on those patterns, there are few files better than the pagefile to place on an SSD.
Windows dynamically manges your pagefile, if you've got 16GB or ram then your PF will be small anyway.
You're spot on, it may dynamically manage the current size in use but it still reserved the maximum amount just in case.
Having said that, with 16GB or more of RAM I doubt if it would really matter that much in practice, at least in normal use.
building a dedicated photoshop pc with 16gb ram installed and also have ssd.
is it advised to keep all 16gb of virtual memory or can i reduce it to a sensible size to save space on ssd.
thanks Ali
You don't have a clue.
Go read the documentation. You behave like a child.
require a lot more virtual memory on top of their ram.
