Wrong. Some programs refuse to run without virtual memory, so its not effcient. Just set about 1.5x - 2x the amount of ram for Virtual memory.DragonWoLf said:my lecturer goes that if u have 2gb of memory and turn off virtual mem then ** systems runs more effciently(sp)
Allowing windows to dynamically resize the pagefile size will lead to it becoming fragmented and kill performance.Etaqua said:Letting Windows handle it automatically is usually the best, and easiest answer.![]()
Fourstar said:Allowing windows to dynamically resize the pagefile size will lead to it becoming fragmented and lead to a loss in performance.
Then he shouldn't be lecturing.DragonWoLf said:my lecturer goes that if u have 2gb of memory and turn off virtual mem then ** systems runs more effciently(sp)
That depends on what he lectures on i supposeNathanE said:Then he shouldn't be lecturing.
Definitely, even a 13/14 year old kid on the forums right now knows than you're lecturer is very wrong. Uhh, can i have his job please? better than a paperound...NathanE said:Then he shouldn't be lecturing.
I used to think like this until I saw this article: http://www.tweakhound.com/xp/virtualmemory.htmNeon said:no virtual memory for meat all....
i run 2gb its not needed is the virtual memory.
