28 Apr 2010 at 20:42 #1 Conrad11 Conrad11 Soldato Joined 12 Jun 2005 Posts 5,361 When the keyboard is locked into the virtual machine is there anyway that when you press Alt+Tab is cycles through the Windows programs as usual? Thanks.
28 Apr 2010 at 20:50 #2 bledd bledd Don Joined 21 Oct 2002 Posts 46,868 Location Parts Unknown you know you can press right CTRL to exit it.. also, install the 'additions' look through the menu whilst you have the VM open
28 Apr 2010 at 21:01 #3 Conrad11 Conrad11 Soldato OP Joined 12 Jun 2005 Posts 5,361 Yeah I know, I keep just pressing Alt+Tab to exit so I'm hoping to make that work. (Have already installed - but thanks!) Edit: Found the option in "Preferences". Just uncheck "Auto-capture" Last edited: 28 Apr 2010
