Hi,
On occasion I used Oracle's VM VirtualBox V 4.3.6, I have Windows 7 professional as the host and I run the latest Ubuntu as a guest.
After a cold boot of the host, VirtualBox loads up fine and I can run and use Ubuntu. When finished with the guest I always power it down. If I cold restart the host then the guest will run fine again.
However, if (after having shut down the guest and virtualbox) I hibernate the host and then resume again, the guest will not load. It goes through the early motions but then just sits on a blank screen.
The guest will only ever work after a cold boot of the host.
Any ideas?
Any ideas?
