Virtualization Lab / Gaming Build
9 Mar 2008
Hi,
I'm looking to upgrade from an i7 920 / x58 set-up which is getting a bit long in the tooth. I'll mostly be using it as a virtualization lab (VWware Workstation / Virtualbox rather than ESXi / Xen etc.), so >4 cores and plenty of memory (32GB) is required, but will also be doing some gaming (mostly strategy and 4x games). I already have a decent GFX card that I'm not looking to upgrade, but I'm a bit out of date with CPUs / motherboards. It looks like the Ryzen 1700/1700x and x370 might be a good value option, although I understand they need high speed RAM for best performance? Is there a comparable option from Intel that I should be considering?
Any help would be appreciated.
Thanks
I haven't considered it too much, but I think max £800-1000 for CPU, Mobo and RAM.
In terms of gaming, I currently have a 980GTX, which I don't plan to replace, and resolution is 2560x1440. Tbh, I've found the i7 920 fine for most games to date, so any update would probably be fine on this front!
I wanted to consolidate my server/storage/vms into a single machine and ended up with a Threadripper build, plays games well, and great for development / heavy virtualisation work (for me at least).
You could probably get the 8 core (and highest clocked) TR CPU with the Asus Prime board and 32gb ram (possibly?!) on that budget
I'd probably go for something like this. You get your 16 cores and 32GB of RAM but also a nice fast NVME drive to put your host operating system on, and a big 500GB still fast SSD to put at least some of your virtual machines on. Although I only run a single VM on my machine at work putting it on a dedicated SSD made a huge difference and it essentially feels just as fast as the host it runs on.
My basket at Overclockers UK:
Total: £1,161.04
(includes shipping: £11.10)
Thanks for the recommendations all. I went with a Ryzen in the end - Threadripper worked out to be a bit expensive, and I don;t really need all the extra PCI-E lanes. I put some of the differenc einto storage though, as suggested. Thanks!
