Virus removal?
16 Jan 2006
Internet
I wanted to know whats the best software out there to remove viruses and malware, spyware, adware and so on.
i know about malware bytes anti vir and spybot and adware.
any more that i can use to help remove unwanted guests on my pc :) also if any of the above are crap could you let me know whats better.
THanks
Dave
you have mentioned a two very good apps in Maleware bytes and Antivir
add SuperAntispyware to the list to replace spybot and adware
Also Combo fix is well worth running to check for extras the above apps miss
a decent HIPS/Sandbox may be a idea once the pc is clean Defense wall is a great app for a clean pc
