Vista 64 Bit & Cpu temp monitoring
Permabanned
16 Sep 2003
Plugged into the Matrix
Just wondered if there was anything out there that works on Vista 64. Would really like to be able to use TAT, but that dont work on the 64 Bit only 32 Bit.
Any ideas?
Hi you could use core temp beta 0.94 works in Vista 64 bit if you press F8 at boot and disable driver enforcement :)
works for me
Thanx 00NukE
