Vista 64 bit, re-install
30 Jun 2004
Morning,
I am in dire need to frmat computer and re-install vista 64bit. I will also be adding another hdd in the system (for OS to sit on), how will this work with the Vista fraud system, will i need a new code etc.
Thanks,
You won't need a new code - you will have to reactivate it though.
It would be easier if you got your new HD first in all honesty.
M.
